How easy is it to retrofit electric seats in an NG900 convertible? :D I did it in my last car which was a BMW 328i coupe and it was fairly straight forward - I just took the +ve from the cigarette lighter... I thought the chances of both seats being adjusted whilst simultaneously using the lighter were fairly slim! It worked out fine... Could I do a similar thing on the Saab? What kind of connection do the seats have?
The seats have two plugs, and each plug has several pins in it. Maybe someone with a Haynes book can check the wiring diagrams and find out exactly what type of connections they are.
The rather useless (in many cases) Haynes manual seems to have nothing on this.
If the manufacturer has pre-wired the car for power seats, then you are in business..
I have a sneaking suspision there is power plugs under the carpet for fitting electric seats, should be an easy upgrade.
