It's made by Thule but has Saab printed on it so I think it is the official Saab branded roof rack.Depends if it's a generic Thule rack with some fit kit, or a rack specifically made for the 9-3.
Awesome, thanks for the info and response!Well, the good news is that the youth are tuning Saabs, and roof racks on top are in style, so you should be able to get some reasonable money if they are in good condition. Maybe check how much roof racks are selling in your area; around here decent but not immaculate unused roof racks would be a reasonably quick sale if priced somewhat over $50.
You may also get someone who wants to actually carry stuff like lumber on top of their Saab! Roof load limit is 100kg, beats any Volvo roof spec I've seen
Good plan, although getting the ball off the arm proved impossible. But I did get the linkage, including the bracket holding the other end to the control arm.Or unbolt ball part.
Poncho replied to my query but I think he may have been refering to the cover for the filter. I'm looking to remove the plate between the Haldex unit and the differential. I've seen a video where it seems to fall off but I can't budge it.09x sedan with Haldex renoved from car/ Need to get the rear cover off but can't seem to remove it. Any suggestions?
Sorry Pancho for incorrect spelling.Poncho replied to my query but I think he may have been refering to the cover for the filter. I'm looking to remove the plate between the Haldex unit and the differential. I've seen a video where it seems to fall off but I can't budge it.
Use something relatively thin & strong (pry bar, flathead screwdriver, etc) & tappy tap it off with a hammer working your way around a little on opposite sides each time. You want to be gentle enough not to cause damage where each side won't seal properly on reassembly....you're not looking to pry it off in one go, you're looking to break the corrosive bonds all the way around & let it fall off like you've seen.Poncho replied to my query but I think he may have been refering to the cover for the filter. I'm looking to remove the plate between the Haldex unit and the differential. I've seen a video where it seems to fall off but I can't budge it.
Another question regarding Lime, I expect it has the pull-on, pull-off high beam selector, same as my other Saabs. Did you change it for a Euro style high beam selector where you pull and leave forward for high beam, and push back to go to low beam?My Lime has low beam xenon and H7 is high beam. This is "xenon 2" setting in TECH2.
Low beam xenon do not have moving shutter at all.
You can change headlights to EU version, which have bi-xenon (with moving shutter) AND H7 high beams.
Audio/navigation has separate manual.
That is terrible idea unless your cars are away from each other all time.if we clone a CIM, that will copy the keys. Could we clone a singe CIM and have the keys work for both of our 9-3s? How nice would it be to just grab a key and get in any 9-3 you have?
Of course unlocking the car you select unlocks all, and when we use comfort open they all would open.
Terrible idea? Yes. It would be a gimmick.That is terrible idea unless your cars are away from each other all time.
You can reset CIM and use new keys, but you can not use key which is already married to another car.
