5481 - 5485 of 5485 Posts
Buy a tech2 already.
Ed:
Remove UEC maxi fuse 37 and put in next empty place (T).
Input fob to ISM and turn it ON. Now you should have SID text: "Transport fuse removed"
Remove key and lock car.
When you want to start use car, insert maxi fuse 37 on its place.
Insert fob to ISM and turn it ON. Now you should have SID text checking -> Check OK.
Is that for me? I have a Tech II in my posession. So does the shop. We've swapped the door lock mechanism and the switch packs on both doors, programmed the switch packs, etc. I've given up on that error for the winter. It's not constant, so there's something funky going on.
If there's a way to check for voltage drains with the Tech II, I'm all ears.
Ed:
I will try that!
Anyone know how to open up/remove the "Load-through Hatch" from the back seat of a 2007 9-3 SS? I imagine I could figure it out, but I've broken little tab clips on other parts going into it without research before hand
