I just picked up my '94 Aero yesterday from Minot, ND. I'm from Canada and I bought the car from Marietta, GA. The car has 122,000 miles on it and is a very clean car. I've already fallen in love with it, just from the 4 hour drive home. I currently own a tweaked '89 900, which makes 241 whp and 291 wtq @ 22psi of boost. I needed to find a clean, fun and reliable daily driver, and what better car than a 9000 aero. This car does not have traction control, which was the only way I was going to ever buy an Aero.
I do have one question or concern with the car. I noticed that the factory boost gage does not read any vaccum. It just sits in the center point between the white and orange, but it does show boost going into the red when I get on her. My thoughts are that either the boost gage is broken or there is a vaccum leak somewhere. The car seems to run perfect, not showing signs of a vaccum leak, but I'm sure these Trionic cars can adjust to a vaccum leak perfectly. Another thing that is weird is when I'm on it hard and take it up in the higher rpm range, the rpms will stick at the rpm I shifted at for about a second and then come down, but slower than it should. It's like the throttle plate is being held open for a moment. Here's my take on the situation regarding the boost gage and this sticking rpm. I think the rpms are sticking there because of a vaccum leak, which is drawing air into the engine between shifts, which then causes the rpms to remain there because of the air being supplied thorugh the vaccum leak. The sticking rpm only happens when I'm driving it harder. It will not stick when driving normally. Does anyone have any suggestions?
I also noticed that the cabin air sensor on the dash is rather loud, like a girgling sound. What's up with this?
What oild do you guys run in your Aeros. I run 20w-50 in my 900, but I'm obviously not going to run that on a stock engine. Should I run 15w-40 or just 10w-30 in the summer. I know that I will never put 5w-30 in any motor.
