I just took off my spark plugs and put in new ones and I noticed the smell of fuel on one of them. I also replaced the valve cover gasket due to the plugs being full of oil. I saw some orange o-rings when i removed the spark plugs but two of them are missing. I was looking for the part number for them, If anyone knows it?
Second part of the story is that I had the infamous code on all 4 injectors and a code on the turbo solenoid that I replaced already. I also cleaned the injectors as well. I also bought another ECM unit too.. Im still getting engine shake and the check engine light is blinking. Do those orange o-rings inside the cylinder head where the spark plug screws onto cause that? I cant seem to figure this out. The check engine light blinks and the car just shakes on idle, but when I accelerate at a high rpm, the shake goes away. Need alot of help here.. thanks
