Apparently the SAAB dealers were told to bend the U-shaped pins to hold the pads more firmly. This was supposed to cure the clunk. I never had much success, and learned to live with the noise.
The hand brake levers needed regular cleaning to free them up, but I did manage to do it by unbolting the calipers, but not always disconnecting the brake pipes, so avoiding bleeding the system.
Don't overtighten the handbrake cables, or eventually it will stop working altogether. Adjust the levers on the calipers using a feeler gauge, as described in the red edition Haynes manual (worth getting if you haven't got one. They do come up on e-bay), to as near their specification as you can get.
After you have wound the pistons back in, and then replaced the pads, you have to pull on the hand brake (5 clicks or so from memory) and then pump the brake pedal. It takes a lot of quite vigorous pumping, (if you know what I mean!) to reset the adjustment.
In the end (130,000 miles) I bought 2 reconditioned calipers from Two Stroke to Turbo. Almost no clunk, and a handbrake that works a treat. About £60 each.
Good luck.
