Pulled into my parking spot at school when I got home. When the RPM dropped to idle, it started idling really rough and flashed CEL with error code P0300 - multiple random misfire detected.
A quick Google search showed bad ecu, bad throttle body, intake valves, or simply faulty spark plugs (it has been awhile since I've replaced them. Running Ngk bcpr7es.)
The threads mentioned that the car ran rough and didn't drive right for all culprits above except spark plugs. Could it really be simply spark plugs?
Also have P0455 large leak detected. Not sure if related because that code I've had for some time now and goes away randomly. Was actually in the "history" of codes.
I need some Saab geniuses here.
Thanks guys
Sent from my SM-G930U using Tapatalk
Thanks guys
