I have never seen this fully discussed or answered, so I thought I would ask. With the dipstick on the 9-3(not sure about 900) it is spring loaded I believe so that you need to push it down, and turn the dipstick to release it from the engine. Then when you put it back in you need to push it down all the way, turn it, and then let it lock in place. So my question is, after removing the dipstick and then wiping it off, do you:
A) Push the dipstick all the way down as if you were going to lock it, and then pull it out and check it.
or
B) Push the dipstick down till it hits the plastic, and then pull it back out and check it.
Thanks,
Doug
or
Thanks,
Doug
