Hello,
I own a 2005 SAAB 9-5 ARC sedan, currently with 113,000 miles on it. Most recently I have had trouble with the vehicle randomly cutting out, jolting and it seems like it isn't getting enough air in the turbo.
As far as the cutting out problem, it has happened twice recently, while sitting at a red light, in neutral, the vehicle will just bog down and shut off. Yes, there was more than enough fuel in the car, and I was not in gear. The vehicle also jolts, I would describe it to popping the clutch to quickly on take off. To address the air/turbo issue, it sounds like you take a vacuum cleaner and place a plastic bag over the end.
I do not know what to do, the car has 113,000 miles on it, I change the oil every three thousand, all of my fluids are at the right level, I don't have any fluid leaks, and I baby the car driving.
I recently put a tester on the vehicle,
Receiving 4 codes.
P1312
P1334
P0340 - "Crankshaft position sensor, A circuit bank, 1 or more sensors
P0304 - "Cylinder 4 misfire"
The other two above codes, my machine was unable to give a definition for. Can anyone tell me what the above two descriptionless codes are?
Also what steps should I take to get this fixed? or should I just trade it in.
Thank You!
Receiving 4 codes.
P1312
P1334
Thank You!
