A fun and fantastic two weeks of driving my 1994 SAAB 900 Turbo Convertible, and I've hit my first real problem. The battery died on me.
I got a jump from a friendly passerby, then half way home the battery died on me while driving. Damn. Sounds like the alternator.
Ok, I dissect the problem further, and it looks like the alternator is giving charge, just not enough (about half a volt). The battery light on the instrument panel doesn't turn on, and a local mechanic shows me how to get the alternator up to an even 14 volts if I just connect a test light from power to a connector on the back of the alternator. Now the instrument panel bulb, known to affect charging when it burns out, is the most likely suspect, and I vaguely remember thinking "Why is the battery light so much dimmer than the others?"
Which would mean I need to buy a 70 cent replacement part and live happily ever after. But then I go and swap out the charge warning light bulb with another, less important bulb (check engine, hah), and lo and behold that doesn't make a lick of difference. Hell, the battery bulb doesn't look burnt out, and I can't even get the leads for the battery indicator bulb to show a voltage (but to be honest it is a damn awkward angle).
If I could get the alternator to manually turn on (the friendly neighborhood mechanic wasn't terribly descriptive in his methods), then I'd at least be in the clear to drive the thing while I figure out the underlying problem, but so far no luck on that front. Is this info pointing to some other likely culprit? What is going on here?
