1 - 10 of 10 Posts
For the right side front door, a power window motor may be necessary, I am doing a test right now - the motor is extractable in several pieces...one piece if one can keep the white plastic brush holder assembly in place...as the unit is being removed...
Just remove the 4 screws..
more to come.:cheesy:
She tests out fine (UP) but nothing (DOWN)....so there must be a dead circuit at the brush holder ....a solder crack ???
We also need a dimmer switch for the '96 900S
"Bross ?" 193 038-XXX 569
Bosch FPG 12V 0 130 821663
no shortage of numbers......
fascinating how an electric motor can run either one direction or the other, depending on the input from the switch...
Do we have a dimmer ?
46 17 460
TIA
Reverse auction
$30 for both the correct dimmer and a good motor.
We should have at least two sellers, maybe more than one buyer....
Responses ?
Maybe I should dig up an electronics repairman...The $400 TV acts strange at times...its an IC or a mini-module with both the dimmer and the motor.
Patience ?
Responses ?
Patience ?
shameless bump...or I am out of luck...
46 17 460
TIA
Now $50 for the two.
But - one day only !
120 degrees outside ! ...this morn - its a very hot sun...
114 in the "shade" !
Will I be able to re-check the motor , as suggested ?
Actually the motor itself is good, I think something is amiss in the electronics.
Plus, I'll have to install new green rollers (one was completely broken.)
They should arrive today from eEuroParts.
The new rollers (green plastic) are installed.
The motor ran the glass up and down 2 times....perfectly
But she failed on the third DOWN.
And now, on UP , the motor spins (removed from its receptacle); but
DOWN ......nothing...
I could use a known good slave motor, but .....there is none to be had..
Now, I am convinced that it is the motor assembly.
Now to find someone to sell one.
I am parting out my beloved 1995 900 super car. ALL of my regulator assemblies and motors are perfect. PM me to discuss terms my old friend.
1 - 10 of 10 Posts
