Well the positive cable has some corrosion where some parts are barely showing the actual wire. I replaced my battery in the middle of august. But steering while driving feels normal until I turned left then it locked up and while car powered down. It started up again and I drove home luckily. Also since it started raining my passenger floor board gets wet only when it rains thoughYou need to make sure your battery connections are clean and tight.
Need more information about power steering pump. If power steering fluid looks normal and is normal level, and steering isn't really heavy, then it would appear to be working.
Also my ex had looked my in my power steering reservoir I believe it’s called and had me turn my wheel one way then the other and he says it’s not circulatingWell the positive cable has some corrosion where some parts are barely showing the actual wire. I replaced my battery in the middle of august. But steering while driving feels normal until I turned left then it locked up and while car powered down. It started up again and I drove home luckily. Also since it started raining my passenger floor board gets wet only when it rains though
I will double check though on the connections thank you will keep you postedIve seen a similar problem like this. Make sure your battery is secured with the holddown. The battery might be shifting around and the batt connection is coming loose.
in the short term you need: good healthy battery, secured, clean tight batt connections.
The batt terminal wires will corrode and develop resistance so that may need to be addressed as well.
I replaced the positive terminal side of my batt circuit based on the findings of voltage drop testing. There was even a technical service bulletin on this problem.
Ok so I charged my battery to be safe and had it tested at oreilys auto parts and everything is good there. I did notice the tray the battery sits in as well as positive battery connection cable is corroded and needs replaced im having a hard time finding the right one my sons dad is trying to help and has my car so I can’t see the exact battery cable size length etc either any ideasIve seen a similar problem like this. Make sure your battery is secured with the holddown. The battery might be shifting around and the batt connection is coming loose.
Lets hope it's only the clamp being corroded - if it's the cable being shot on a length there are two options:Ok so I charged my battery to be safe and had it tested at oreilys auto parts and everything is good there. I did notice the tray the battery sits in as well as positive battery connection cable is corroded and needs replaced im having a hard time finding the right one my sons dad is trying to help and has my car so I can’t see the exact battery cable size length etc either any ideas
Well I was thinking going to pick and pull to see if I can get the positive cable however was wondering if a positive cable from a 9-5 2004 Saab is the same as mine 05 Saab 9-3Lets hope it's only the clamp being corroded - if it's the cable being shot on a length there are two options:
- replacing the harness (12797748 for halogen, 12797746 if car is equipped with Xenon; $$$)
- getting the harness repaired by a qualified car electrician.
And while the battery is out you might want to restore or replace the tray (12789449 or 12761146).
Turning hasn’t been an issue other than the car cutting off.Engine cutting out on turns sounds to me like an electrical problem where the cornering force and/or things moving around are breaking a connection and therefore engine stalls.
If the PS fluid level is normal and fluid looks normal, and steering is possible, then I wouldn't worry about the PS system.
No, different car, totally different engine. It looks like what you need is a battery cable from an NG9-3 with a 2.0. That would be 2003-2011, except 2003 convertible.Well I was thinking going to pick and pull to see if I can get the positive cable however was wondering if a positive cable from a 9-5 2004 Saab is the same as mine 05 Saab 9-3
Thank you for that info, makes sense though I was hoping. I can’t seem to find the positive cable anywhere local and not sure where to buy it online that’s not to expensiveNope. You need battery cable from ng 9-3 which has SAME ENGINE.
Thank you that helps me in my search😎No, different car, totally different engine. It looks like what you need is a battery cable from an NG9-3 with a 2.0. That would be 2003-2011, except 2003 convertible.
Problem: if you get a used cable you have to keep in mind that it is also being more than a decade old, and you don't know whether it was being pulled out the correct way or rather being yanked out without much care. That's why I had suggested to see a qualified car mechanic who looks after it and can tell you if it is possible to repair the old one or if it needs replacement.Thank you for that info, makes sense though I was hoping. I can’t seem to find the positive cable anywhere local and not sure where to buy it online that’s not to expensive
I feel stupid for this but I’m not sure mine are halogen lights but I kno the bulb is h7 so I’m guessing notProblem: if you get a used cable you have to keep in mind that it is also being more than a decade old, and you don't know whether it was being pulled out the correct way or rather being yanked out without much care. That's why I had suggested to see a qualified car mechanic who looks after it and can tell you if it is possible to repair the old one or if it needs replacement.
ebay has a NOS harness if your car is equipped with halogen lamps: Saab CABLE HARNESS 12797748 Saab 12797748 | eBay
Another alternative might be a workshop which is specialized on manufacturing out-of-stock harnesses.
It is halogen.I feel stupid for this but I’m not sure mine are halogen lights but I kno the bulb is h7 so I’m guessing not
