Power steering leak.
879 views 5 replies 4 participants last post by  skilpadda
#1 ·
I have a leak from the large pipe on the power steering reservoir that runs to the rack, I can see where it has rubbed against the body causing a weep from the pipe.
Is this a special pipe or just normal heater hose type pipe??
If I disconnect the pipe at the rack, I assume that I will loose only the fluid in the reservoir, not all the fluid from the system??
Cheers guys
