1 - 20 of 25 Posts
I have a 2005 9-3 arc and the passenger power seat has never been operable. The seat warmer works just fine though.
Is there a fuse or relay somewhere I could check?
Thank you
Fuses and relay for electrical seats are in the REC (rear electrical center) in trunk behind drivers side rear wheel
MAXI fuse #4 40A
MINI fuse #25 30A
Relay is R1 (relays are on back side of REC)
Discussion Starter #4 (Edited)
I checked these fuses AVguy mentioned. They all look fine. What else could be the problem?
Should I pull the seat out and look under it? Is there a plug somewhere that could've came unplugged?
Thanks
Check that M button is not pressed down all time.
Check that you have voltage (power supply) under seat connector pin 37 (red 4.0 mm2 wire)and pin 38 (black 4.0 mm2 wire) is in ground.
Discussion Starter #8
I took the cover off the side of the seat where the control switches are and tested it with a test light. Didn't see any power coming to it. I wonder what could be the problem.
Hello guys,
can please help me somebody. I am from Germany and have a problem with my 9-3 cabriolet My04!
The passenger seat are not working. I checked the fuse F4 and its fine! The heating is working.
So were can I find the fuse for te passenger seat?
MAXI fuse #4 40A
MINI fuse #25 30A
Is this Relay for bouth seats or just the passenger?
No relay.
Passenger seat fuse is 25 (30A) in REC.
What do you mean with no relay?
It is a relay behind the REC for the passenger seat and the fuse 25 is for the driver seat!
MY-04 Cabriolet (CV)!
Fuse 25.
If you lied about your car, ignore my advice.
What car you have?
If you have BMW, ignore my advice.
If you have my-04 convertible/cabriolet, follow my advice.
Then I highly suggest that you can read and choose right version.
What you think?
Bad weather?
You can not use multimeter?
Where can I check it, which conector, with the multimeter?
Is it normal that the passenger seat has an Memory Modul? But I don’t have the buttons for Memory! Here the picture!
269973
1 - 20 of 25 Posts
