Believe it or not the 02-03 9.3 verts (old body style) didn't have a lock/unlock door lock button. It was replaced by the switch that puts all four windows down with one push. You would have to either use your remote with the key out of the ignition or pull up on the lock knob on the door.
Now if you are actually talking about an 04- 9.3 vert (new body style), it would be on the door panel BUT some of the early 04 verts did not have one. If this is the case ask your dealer and they will (should) install one for you under warranty
