Hey Guys and Gals, I have an engine swap question on my 2002, 9-5. I'm thinking of replacing my 2002 B235E with a 2007 B235R. I have both blocks and both need new pistons (I have already ordered 90.5mm Wossner pistons.) I'd be swapping for the updated crankcase ventilation system, bigger trap w/huge nipple sticking into the big block hole. I'd use the smaller E turbo (w/new core,) on it so I don't need to tune it. My question is about the B235R throttle body that's different than my 2002. It has the big nipple near the base and big hose that goes to the oil trap. Will the newer R throttle body plug and play the same as the my E throttle body, and work with my ECU the same? If not is there a simple remedy? Of should I put the Wossner pistons in my E block and stick with the modified (as recommended,) crankcase ventilation system and call it a day? Thank you!
