So I have noticed an oil leak. Normal for a Saab. Except it's the transmission oil. It seems to be coming out from the flywheel cover (I can see oil trailing out of the timing hole and a small weep hole that's lower and on the driver side). It only seems to lose a pint of fluid tops, so I'm not too sure as to why this would happen. Could it be a cracked case? Or just a worn out seal? I'm so confused.
P.S. Is the flywheel cover supposed to be made out of plastic? That seems so wrong in so many ways.
