Possessed Turn Signal and High Beams 2006 9-3
Hi all! I just bought a 2006 9-3 for my daughter and am working through a few issues.
Issue with the turn signal: the left turn signal will occasionally decide to flash (all marker lights plus dash indicator) while driving.
Issue with high beams: I am assuming the lever should make a click and the beams should either be low or high? I get no click and the high only works while I am holding the lever. (I understand the switch and this is with the switch in any position)
So - based on some online research, I was at first thinking of just replacing the leaver/switch. This looks simple enough - push a small screwdriver into the hole to release the tab and pull the lever/switch out.
But - then I saw where I may need to take the steering wheel off and replace the whole part for both the turn signal lever and also the wiper lever.
Any ideas? Can I provide any more info to help diagnose?
Thanks!
Thanks!
