The pictogram on my 89 9000 comes on when I turn on the lights and shows that there is a dead bulb in the rear lights. There was a dead bulb, I replaced it but the pictogram will not go off. Any ideas?
Did you replace the bulb with a 'generic' bulb? There seems to be an issue with certain bulbs, that whilst they work, the ohm return is incorrect, and your dash is flagging it as having failed as it is outside the range that it expects to see.
If you can, test it with a genuine bulb to see if this resolves the problem.
Cheers
Kenneth
pictogram
Went to the parts store and got a generic, but they have worked just fine in the past. I will try another brand though. Is there a way to reset the the pictorgram? such as disconnecting the battery for a while?
X
Guest
This is just a guess, I had a similar problem with my 9-5. The unit sences current resistance from the bulbs if they are not matched ie one old bulb one new, it still thought that there was a problem. To fix I changed both bulbs for a new matched pair and the light went out... :confused:
Discussion Starter #6
Fixed it
FIXED IT! Problem seemed to be the resistance in the first replacement bulb. Put in an Osram/Sylvania replacement and everything is ok. The first replacement bulb was made in China, the Osram/Sylvania was made in Italy. Draw your own conclusions... I sure have!
Thanks for all the good advice!
