I’m working on replacing the engine mounts on my wagon because I have a decent shake at idle/in drive and I’m wondering how I should know if the specific engine mounts are bad
For the passenger mount, I took the elk horn/wishbone off and I can move the bolt back and forth but there is definitely some stiffness present. I can lift the bolt up and down like 2 inches or so, with the black circle thing inside the mount moving with it. Are these things normal?
Is there a way to test the other engine mounts also or should I just replace them?
