Part number for cooling pipe
146 4
What’s a part number for this metal pipe? Circled in yellow
It goes from turbo (under the heat shield) to coolant hose p/n 12787815
Also, why would that bolt highlighted in blue got loosen? Vibration?
Nope.
It’s a metal pipe which gets inserted into rubber tube 12787815 on the picture referred as #40 . Coolant hose. Which goes around valve cover on the left side. Connects three way coolant connector and turbo. I need that metal piece of the pipe with fitting which goes into turbo.
The winner gets a 🏆
…and the prize goes to….aerojon.
Bingo! Thank you so much!
exactly what I need, gaskets, seals, etc….
On diagram that pipe is drawn away from the turbo, not intuitive. Thanks aerojon for catching this.
working on mystery coolant leak after valve cover gasket replacement. Perhaps I pulled that line too hard. Looks like there is some leak at a turbo. I assume it’s a low risk to replace gaskets in there or it’s better not to touch that area?
