1 - 19 of 19 Posts
On my previous 9-5 I had an issue with the parking sensors. I was told that if one sensor is inoperative then the whole system stops working leading to the warning on the SID. I found out which one was causing the problem and hey presto, they all started working.
Now on my current 9-5 I have parking sensors that just don't seem to be up to much. They only pick up objects when they're quite close and from some angles don't seem to pick up anything at all. Keeping in mind the 'one out, all out' nature of the sensors is it possible that their performance deteriorates? But if the above is true and one or two are faulty surely they'd all stop working?
Possibly related but the one on the NS edge doesn't seem to be the correct type. Rather than being round it has a squared off top and bottom. But again, if this one was faulty surely they'd all stop working?
*sigh*
What TECH2 says about sensors?
Round and squared are same, difference is shape.
SAABless booo
Mine only work when it's really hot outside.
You really need a Tech II to see what the SPA module is actually reading, and possibly if it has any error codes stored.
I'm not looking at WIS, but I assume that their troubleshooting procedure for SPA involves much use of a Tech II.
With manual transmissions, it's worthwhile to check that the backup lights are on when the car is in reverse. If the switch fails, then the lights aren't on, and the SPA isn't activated. This should not be an issue with auto trans, as I assume the SPA is informed via the bus that the car is in reverse.
SAABless booo
Mine as well. What Is the deal with that? I thought it was a coincidence.
OMG! I thought it was just me lol. I have no idea why it's like that. I've checked all the wiring, everything seems to be okay. It's just the heat that activates them or something.
Discussion Starter #8
lol bizarre! I used to have a Volvo where they were on all the time if it was raining but only working when it's hot is a new one on me.
Discussion Starter #9
Hmm. I'll have to find someone with Tech2. It is an auto and no problem with the reverse lights.
Rich the park sensor with the racetrack shape face is pre-2005 and apparently they're not exchangeable. I sometimes get the constant tone on my 2004 when I select reverse but haven't related it to weather conditions or anything else.
It doesn't happen often enough for me to be bothered to remove the bumper to check wiring (its an estate). I had it Tech 2 interrogated and two of the sensors were reading incorrectly but next day it worked fine.
Incidentally, when it is misbehaving and giving the constant tone, all four sensors were ticking. One sometimes hears that the faulty one doesn't tick - not so.
Also, if it does give the constant tone, you can shut it up (for that event only) with the clear button on the SID after the "PARKING ********" (I can't remember what it says) shows in the display.
I fitted a set of non OEM sensors for a guy with a 2006 a while ago. As far as I know they still work. I see on ebay there is a set from Germany for 35 euros which tempts me but they're probably not made there!
Doug
Discussion Starter #11
Cheers Doug.
The one with the squared off top and bottom is an annoyance more than anything. Just doesn't match the other three!
I don't get the constant tone unnecessarily, I just get very little warning of an object. Even something as large as a parked car behind me goes from no tone at all to a very rapid tone/constant tone as if I'm about to hit it.
Is it really a bumper off job to change the sensors on a saloon? I notice the black plastic bump trim is quite easy to remove.
It is exactly same than others, difference is only shape.
Thats useful info. Every day's a school day.....
Rich - its bumper off for the estate (although there is another method which seems too complicated/dangerous for me) but as you say, the black strip pulls off on the 4-door.
Doug
Discussion Starter #14
Great. Might have a punt on those cheap eBay ones if not to stop my OCD alarm going off every time I look at the back of the car :cheesy:
I have had no luck with the cheap chinese sensors...either they dont work at all or they bleep continously regardless of distance.
I never learn thrown three in the bin on the last year....end up buying used ones which usually go bad again within a year or two...but hey ho still wont pay the ridiculous price for a new one though.
I use Peugeot/Citroen sensors. They are same, but costs about half.
I do not met any good chinese sensors.
SAABless booo
Hey Mimmi, do you have a product number for those sensors?
From what I researched, there's a sensor specific to 2004-05 9-5's. 1998-2003 use a different sensor and Dame Edna's use a different sensor. All the Saab part numbers are different which makes this confusing.
PSA P/N: 9653849080
Saab uses 3 part numbers, because 2 first are in different shape and last one (for dame edna) is from another supplier.
They are all same sensor.
Discussion Starter #19
Well I did have a punt on the cheap ones. Specifically these. Pleased to say removing the mismatched one was a doddle and the new one works perfectly. And obviously I have three more unused for now.
1 - 19 of 19 Posts
