Most parasitic draws are vexing but this one appears to have different modes.
A. When first applying power to the system using an in-series amp meter, current flows at 2-3A and then settles down to 0.15A after 30 seconds.
B. If either door is opened and then closed, current flows at 4-5A while interior lights are illuminated, after which the current draw is between 2-3A. This draw continues for at least 5 minutes, maybe longer.
C. Removal of the F30 MAXI fuse drops the draw to approximately 40mA.
Questions:
1. What set of small fuses are wired through the F30 MAXI?
2. What does the door open/close sequence tell me about the systems that are activated and appear to continue drawing power?
3. Is a 0.15A (150mA) parasitic draw acceptable?
4. There is an audible "click", emanating from the vehicles drivers side, that first "opens" and then "closes" within the power-up sequence. This sounds normal but is this something that should be further investigated?
Full system shutdown(modules/ECU etc) after locking the car is probably at least 10mins (its about 15mins on a 9-5 dont know exactly on the 9-3)
So you need to measure later and see if it drops in stages...again on the 9-5 its 10-30mA by the time its done its thing........I would have thought the 9-3 would be same ballpark,
You need to look at the wiring diagrams in the WIS for the fuse layouts.(download Tech2 section or www.saabwisonline.com)
Look for interior buttons lit after the car has gone to sleep.
I traced the draw to the ISM as was suggested by jglover. I had been having intermittent steering lock issues and so I should have realized that was a clue. Replaced with an OEM ISM and the draw is now 10miliamps. Thanks everyone.
