1 - 13 of 13 Posts
How did you end up going with making a clear headlight lens?
The link is a bloke who makes slump acrylic lenses for his 240SX.
He probably sells them too as he's made a lot of them.
How about pouring water clear resin into he inside of the glass lens so that it flattens the flutes out?
There is a guy in Russia who makes them.... $75 per pair. Go to ebay and search saab clear projector polycarbonate
Still working on it... current health situation makes it difficult since nobody is accepting work. And my project is for a c900, probably wouldn't help you much.
Not specifically but the technique wouldbe the same.
The only type of process that would be available to regular people in small volume is thermoforming. Everything else is simply unsuitable for a light lens (rotomolding) or very expensive (injection molding). To properly thermoform you need good molds and a substantial source of vacuum. I dont think DIY methods are suitable here since it's much harder to get uniform thickness without that good vacuum, and without a uniform thickness I am concerned about creating hotspots on the lens.
The challenge with the old c900 is different than a 9-3, so as a Rev0 I am going to try and make a multipart solution. That way I can take a third route and CNC component parts. I think the final part will look fine on an '80s car but would look out of place on a 9-3.
Probably not useless, but certainly less than ideal. And maybe problematic. I mean, it's been done and people have had acceptable results, but for me the issue is less about light and more about irreplaceable parts. My goal is to have a replaceable parts and th multipiece solution really supports that goal.
Discussion Starter #9
I just tried it - no good at all.
The type and position of the projector is critical. Search around and you'll see a lot of discussions about it for a lot of cars.
Discussion Starter #11
I tried two different types of projector, that's it for me unless I can get a clear lens.
Jake is probably done with Saabs. He sold his personal car and went non-Saab. He used to buy, repair, and sell but I think he's done with that hobby too.
1 - 13 of 13 Posts
