P0455
EVAP. Serious Leakage in System.
Fault symptoms
CHECK ENGINE.
Possible smell of petrol.
On-Board Diagnostics
Type of diagnosis:
Once per driving cycle. Interrupted when fault criteria fulfilled or OK reported. Restarts next driving cycle.
Test 1, Cold start
Enable criteria:
Coolant temperature at start between 5-40°C. Difference between coolant temperature and intake air temperature less than 5°C.
If the above conditions are not fulfilled, Test 2 (warm start) will start.
Idling speed. Max. one change in status of brake light switch. Purging adaptation higher than -15%. Intake air pressure at least 20 kPa lower than the atmospheric pressure. The vehicle stationary for 5 sec. Fuel volume in tank between 11-54 litres. Battery voltage between 10-16 volts. Tank pressure between -300 to +100 Pa.
The diagnosis will start once the above conditions have been fulfilled for more than 5 seconds. If the diagnosis is interrupted then the speed must exceed 0 on one occasion before it is allowed to restart. The diagnosis is divided into 3 phases, A-C:
Phase A) Evaporation check The shut-off valve is activated (closed) at the same time as possible purging is stopped for 4.5 sec. Tank pressure is observed, falling pressure reveals leaks in purging valve. Rising pressure of more than 3 Pa/s points to fuel evaporation, in these cases Phase A is repeated. If it becomes apparent that the pressure is rising by more than 3 Pa/s the diagnosis is interrupted, vehicle speed is needed during a certain time for it to be restarted. For pressure increases less than 3 Pa/s then Phase A is complete. The diagnosis continues to Phase B (pressure reduction)
Phase B) Pressure reduction Shut-off valve is still closed, the purging valve's pulse ratio is set at 23-24.5% until the tank pressure has reached -600 Pa. This pressure reduction should take no more than max. 30 seconds.
Phase C) Pressure retaining The shut-off valve is still closed, the purging valve is closed. The tank pressure is observed for max. 12 seconds.
Test 2, Warm start
Enable criteria:
The following conditions should be fulfilled for 5 seconds so that the diagnosis can start: Coolant temperature and intake air temperature at start exceeds +40°C and the difference between coolant temperature and intake air temperature is greater than 5°C.
Idling speed. Max. one change in status of brake light switch. Purging adaptation higher than -6%. Tank pressure between -300 to +100 Pa. Inlet air pressure at least 20 kPa lower than the atmospheric pressure. The vehicle stationary. Fuel volume in tank between 11-54 litres. Battery voltage between 10-16 Volts. Tank pressure sensor diagnosis must have reported OK.
The diagnosis will start once the above conditions have been fulfilled for more than 5 seconds. The diagnosis is interrupted if the purging adaptation exceeds -8%. If the diagnosis is interrupted then the speed must exceed 0 on one occasion before it is allowed to restart. The diagnosis is divided into 3 phases, A-C:
Phase A) Evaporation check The shut-off valve is activated (closed) at the same time as possible purging is stopped for 4.5 sec. Tank pressure is observed, falling pressure reveals leaks in purging valve. Rising pressure of more than 4 Pa/s points to fuel evaporation, in these cases Phase A is repeated. If it becomes apparent that the pressure is rising by more than 4 Pa/s the diagnosis is interrupted, vehicle speed is needed during a certain time for it to be restarted. For pressure increases less than 4 Pa/s then Phase A is complete. The diagnosis continues to Phase B (pressure reduction)
Phase B) Pressure reduction Shut-off valve is still closed, the purging valve's pulse ratio is set at 18% until the tank pressure has reached -600 Pa. This pressure reduction should take no more than max. 30 seconds.
Test 3, Filler cap test
Enable criteria:
Vehicle speed above 40 km/h. Inlet air pressure at least 25 Pa lower than atmospheric pressure. Mass air flow through engine above 10 g/s and that the mass air flow during the diagnosis remains in the interval 85-150% of the value at the start of the diagnosis. The purging valve's pulse width is between 50-65%. Purging adaptation between -10% to -20%. The fuel volume between 11-40 litres. Tank pressure between -300 to 100 Pa or that the test has commenced.
If the conditions are fulfilled, the shut-off valve is closed and the purging is locked at the value it had in the beginning of the diagnosis (50-65%). If the pressure does not fall to -500 Pa within 6 seconds three times while driving then a fault is reported.
Fault criteria:
Test 1 (Cold start)
Phase A) Evaporation check If the pressure falls by more than 27.5 Pa/s then an internal leak in the purging valve has been detected. If the pressure has risen by more than 3 Pa/s then there is major fuel evaporation, Phase A will then be repeated. If it becomes apparent that the pressure is rising by more than 3 Pa/s then the diagnosis is interrupted. The vehicle must be put in motion before the diagnosis can be restarted. For pressure increases less than 3 Pa/s then the diagnosis continues on to Phase B.
Phase B) Pressure reduction If the pressure cannot be reduced to -450 Pa within 15 seconds or if the pressure reaches -450 Pa within 15 seconds but not as high as -600 Pa within a further 15 seconds (30 seconds in total) then a major leakage has been found.
Phase C) Pressure retaining If the pressure rises to -450 Pa within 12 seconds then a small leakage has been found.
Fault criteria:
Test 2 ( Warm start)
Phase A) Evaporation check If the pressure falls by more than 27.5 Pa/s then an internal leak in the purging valve has been detected. If the pressure has risen by more than 4 Pa/s then there is major fuel evaporation, Phase A will then be repeated. If it becomes apparent that the pressure is rising by more than 4 Pa/s then the diagnosis is interrupted. The vehicle must be put in motion before the diagnosis can be restarted. For pressure increases less than 4 Pa/s then the diagnosis continues on to Phase B.
Generation of diagnostic trouble codes:
Diagnostic trouble codes are generated when the above fault criteria are fulfilled and the dependents are OK.
In addition for Test 2 (Warm start) the intake air temperature has not been below 5°C.
P0441, P1441 are generated if faults are reported during Phase A
P0455, P1455 are generated if faults are reported during Phase B
P0442, P1442 are generated if faults are reported during Phase C
Fault criteria:
Test 3 (Filler cap test)
If faults are reported and the engine's starting temperature is between 5-40°C diagnostic trouble codes P0455 or P1455 are generated.
Dependents:
P0444, P0445, P0501, P0502, P0506, P0507, P1444, P1445, P1576, P1577 and (vehicles equipped with TCS) P1925.
OK report:
If all conditions are fulfilled and the diagnoses have been carried out without finding any faults then OK is reported.
Note
Diagnostic trouble codes P0442, P0455, P1442 and P1455 are cleared directly after the diagnosis has reported OK.
Fault handling:
Type III.
Diagnostic help
Fault diagnosis concerns a leak.
Functions in the diagnostic tool related to the fault:
Diagnostic status for the diagnosis.
Activate EVAP diagnosis.
For more information, see Fault tracing strategy for electronic systems .
Note
During the final check of a rectified fault, the diagnostic tool activation command must be used so that Test 1 (cold start) is initiated irrespective of starting temperature.
(From WIS)
On newer 9-5's we replace a lot of purge valves for sticking closed. Put 12v to the valve, on and off, and see if it gets stuck in a certain direction (if you don't have a vacuum tool then suck / blow into it).
Tom
