Trying to figure out the cause of a p0341 dtc (according to the wis its bank 1) code on my 2007 2.8 aero w/82k. I changed both the front and back sensors. I also took apart the wiring harness leading back the me9 (ecu) and reloomed the wires. Wires were pretty stuck together from the engine heat over the years. After reinstalling everything back together, the dtc came back. Wires look ok no breaks visible to the eye. Occasionally the car shuts off when starting up.
Before this I was having multiple misfire issues which has now gone away after change all the coils and plugs.
If you are 100% sure that there is no wire issues, you have bad ECU.
Should have mentioned, I put in a new used ecu after the misfires didn't go away with new coils and plugs. I'm still testing it the car and haven't run it more then a hundred miles yet. Thought the new dtc code was the light at the end of the tunnel. Issues with Camshaft position sensor would have explained the occasional shutting off.
