I have a 1996 Saab 9000 CS and every now and then my check engine light comes on. Usually when I am stuck in traffic. The code is P0133 which is says is Oxygen Sensor Bank 1 Sensor 1 slow response time.
If I have found the right info the sensor should be reading somewhere above and below .4 volts. I logged data for the O2 sensor voltage and for the most part it seems good. It goes up and down between .2 and .8 for quite a while but then it has about a 10 second stretch where it just says 0 and then it works fine again and then it has another 25 second stretch where it says 0 and then goes back to normal. Does that just mean the O2 sensor is bad or is there something else that could cause this problem?
Also, it may or may not be related but my car has been pretty slow to get up to temperature. And once it does get up to temperature sometimes it will go back down to just above the L. And eventually it will go back up to normal. Could that be just a faulty thermostat or is something else happening?
If anyone is interested here is a link to the data I logged.
https://skydrive.live.com/redir?resid=AB997B27DF721604!435&authkey=!AGvDGLddQYQPa3s
The 0 reading shows up at 2:31:39
Thanks for any help!
