That's the problem. Tyre pressure affects grip. Generally, the lower the tyre pressure the lower the grip. So with lower pressure in the rear you get less grip at the rear so you get more oversteer.
Two easy things to remember: oversteer means more grip at the front than rear (and of course understeer means the opposite,) and more spring pressure on the outside wheel of one end of the car increases the loading on that tyre, but reduces the loading on the other tyre on the same axle giving a net reduction of grip relative to the other axle, contrary to popular assumptions. Put another way, if you make a tyre work harder either by increasing the suspension loading through spring rate or roll bar rate (or instantaneously through damper rates) or by reducing tyre pressure, you will induce under or oversteer at that end of the car (under if at the front and over if at the rear)
In my experience the 9000 does not respond well to monkeying with recommended tyre pressures. On the track you could benefit from 2 psi less in the rear than in the front on an Aero, maybe a touch more difference on a standard model.
BTW, you should always increase pressure to change handling balance, never decrease pressure. Tyres should always be at the recommended pressure or higher for safety.
Finally, I find my SAAB 9000 cars like about 2 psi more pressure than specified for light load or low speeds. Always use SAAB's maximum recommended pressures (or even a bit more) for high speeds or fully loaded conditions and use the same pressures front and rear for best handling on the street.
