1 - 7 of 7 Posts
· Banned
my 97 cs stars to overheat after i start racing the engine...the temp just sky rockets...the radiator hose coming from the engine to the intake right b4 the turbo had broken off a while ago, so i changed that, but it might have been a little bit of a smaller diameter hose...u guys think thats the problem?
· Banned
Overheating leads to 'New Headgasket" take the problem seriously.
Suggest a cooling system examination. Rad Flush, New Thermostat (80degrees C) and Fan thermo switch and new hioses were they show any swelling at all.
Mebe even a new Serpentine belt.. those fail spectacularily :)
Pay now or pay large later.
· Banned
i also might have not topped off my coolant when i replaced the hose cuz alot of sluid came out...i put some back in, but i guess not that much...i topped it off and i'll see how everything goes for the next couple days...but thanx for the lookout
· Registered
Not having enough coolant in the engine usually leads to overheating. If the top hose broke away, then I would assume that you have lost a lot of coolant. The correct diameter top hose is also important for the flow to the radiator.
· Registered
the same hose burst with me,luckly when i was stopped, but alas shortly after the heid gasket went :cry: , it was about 1hr after it burst when i changed it and i had only been driving for about 10mins ,she was warm when i filled it up but i didnt put anti freeze in ;oops: ,but i dont think thats what done it, but who kens ;)
1 - 7 of 7 Posts
