Ok so my 95 started overheating.
I was driving when suddenly I heard that beep from the sid and noticed that my car was overheating.
So I turned on my heat and watched it settle down back to normal. Problem is that now I can only drive with the heat on full blast - slight problem.
So asking advice from all who know anything about this. Thanks
P.S. the t-stat didn't go into the red it was right before.
P.P.S. I was having issues before with the t-stat that it would really cool the car way below norm, even up to the point where i'd be getting cold air when set on heat - in this freezing cold weather.
Ok replaced the t-stat by a local shop.
The problem is that now the car fights and then stalls when i put it into drive?????
Anybody know whats happened?
now the car won't even start it just turns over but doesn't catch, and theres a lot of noise under the dash and the dash lights flicker on and off???? HELP
OK All's well. My local shop forgot to reconnect the ground for something not sure what. My friend picked up on that and fixed it for me.
