· Registered
Hello, first of all, excuse my english.
One I decided to change my CD player (broken) for a Pioneer, 1 ISO.
I take out CD and the two wires behind, the two wires with fiber optics, I made a loop with a plastic.
The stereo, works. In the next morning the car show airbag failure, and more failures, and the car does not start, simply the start engine does not work.
I disconnect the batery, and connect again, does not work
https://www.youtube.com/watch?v=ggOOIcq7_k0
https://www.youtube.com/watch?v=j0Ln3WjOns8
https://www.youtube.com/watch?v=yKtYtuD2hs8
I think for myself I do in a incorrect way the loop.
Yesterday after more and more research I connect the second wire of the CD and take out the first of the EHU (Entertainment Head Unit, the actual radio inside the dashboard), and connect where it was, doing a loop. i connectected both to the EHU. Does not work
I connected outside the EHU either does not work
https://www.youtube.com/watch?v=Udp7c7yU7UU
I connect everything how it was at the beginning, and does not work
I think the loop needs to be started again because i dont see the red light in the wires cdplayer... I think maybe taking out a fuse o more than a fuse i can start the loop again?
THANK YOU
· Premium Member
Sounds like you killed your battery. Check your wiring of your new Pioneer. You may be grounding it somewhere and it drained your battery overnight. Buy a new battery.
