hi all
i was changing the brake pads on my saab 9-3 aero (2005). i managed to change the fronts with no problems.
however the backs were more tricky since i had no manual to look at. from what i have read on the net, the rear brake calipers have a 4mm hex nut that retracts the piston, thus enabling you to fit the new "thicker" pads. the front calipers need to have their pistons compressed.
but unfortunatly i have unscrewed the rear pistons way too much, the piston has actually fallan out of the caliper and its rubber housing.
what i need to know is firstly how do i get the damn thing back into the rubber housing, its almost impossible.
second of all when the piston fell out a liquid was behind the caliper, is this liquid some sort of oil used as a lubricant or is it brake fluid, i am asking this because most of this has ended up on the garage floor! so i need to know what it is beause i need to replace it, how do i do that??
many thanks
val
many thanks
val
