1 - 9 of 9 Posts
· Registered
I tried. I swear I've been trying hard but I still cannot find the plug to check ECU faults. Right inner wing doesn't look like it has anything to plug the tester. There's a handler for oxygen sensor but nothing more. It's LPT but I guess it doesn't make a difference. Where this wire comes from? Perhaps if know where to start I will find the other end. :confused:
Ooouuppsss I just lose myself in all these windows. Please move the post to classic saab workshop ;oops:
· Registered
Call me stupid
I may be well of the mark here but when i took mine inot the garage the guy plugged in the tester under the back seat! lifted it up (the bench part) and it was down there!?
any help?
· Registered
On the Lucas system the connector under the back seat is for the dealer 'tech II' or whatever.
To read codes using just a switch anwire you need to find the single female fast on connector loose between the vent air intake box and the inner wing. It's a single yellow/white lead with a black PVC outer sleeve.
1 - 9 of 9 Posts
