I have an elderly 900 T16s (1985) that has been rescued from standing 5 years in a barn.
The car would not start. As spark was ok from HT leads I know ignition is ok so must be fuel system. I suspected the fuel pump so replaced the fuel pump with another known good one (I have loads of them!). The car then fired up, but was mis-firing badly, when turned off it will not restart.
My thoughts are that the fuel is bad, causing the fuel pumps to block and also block the injectors.
The tank was about 1/8 full, and diluting the fuel with 10 litres of fresh has not helped.
Before I start draining the fuel tank and start replacing the fuel pump, filter and injectors I thought I would ask you guys if I am on the right track or do you have any other ideas?
Dan.
Dan.
