and oil would leak from there?Vacuum pump leak is very common, even with low mileage.
thank youI recommend you clean the engine and watch for where the oil comes from. I had a number of leaks so I started at the top of the engine and worked my way down.
Places I've had oil leaking and fixed in this order:
- Vacuum pump. Identified by pooled oil on the rear top driver's side of engine. Replaced seals.
- Power steering pump gasket and reservoir cap. Identified by oil leaking down oil cooler and onto transmission / engine mount, drivers side towards front. Replaced power steering pump with gasket / seal kit to fix.
- oil level sensor. Identified by oil leaking down rear of oil sump (pan). I tried to resolve with dropping the sump and an o-ring I had on hand, but the o-ring didn't work (next time I'll order the suggested McMaster-Carr x shaped one). I temp sealed with RTV, and that took a few applications to get it to stop.
is there a good oil stop leak for a temporary fixit doesn't matter what thickness of oil you use it will still leak..
I'm not a fan of them, it's better to fix the problem's source. I'd put a pan or kitty litter under my car and make it a priority to chase the leaks.is there a good oil stop leak for a temporary fix
its leaking from the right side of motor. for some reaosn i cannot upload anything on this site. i tried to see if anyone would personally message me on whatsapp to see if i could diagnose the problem with helpI'm not a fan of them, it's better to fix the problem's source. I'd put a pan or kitty litter under my car and make it a priority to chase the leaks.
The stop leak may stop the leak, but I don't know enough about them to trust they won't affect the rest of the engine.
Why don't you post where you see the oil leaking from / gathering? If it's an active drip, set a peice of cardboard under the engine. Then take a photo of the cardboard (while it's under your car) that shows the underside of the car and leak spots. Take another photo of just the cardboard once you remove it. There are a ton of knowledgeable people on this forum who may recognize what's leaking and how to fix.
yes im located in missouri. yes the right side is the passenger side. do you happen to also be in missouri?Where are you at - Missouri? Is the right side on the passenger side? I'm pretty sure that's where the pulleys and crankshaft are, so the leak may be coming from that area if its above the oil sump (pan). The vacuum and power steering are on the driver's side.
I suggest you remove your number...if your comfortable please shoot me a message...
umm why? and i wilI suggest you remove your number...
do you work on saabs at all? im from the columbia mo areaI suggest you remove your number...
This is a public forum, in general I limit personal info on those to what people need to know.umm why? and i wil
understandable. well if you caught my number feel free to message because im desperate to fix it and saab forms is a pain to work with sometimesThis is a public forum, in general I limit personal info on those to what people need to know.
