Ok where is this located....i for the life of me cannot find it at all. Ive looked all over and it still cannot seem to locate the damn thing my oil pressure light never lights up even when the car is off and i think the sender may be bad..
anyone know where it is on the 1995 2.3????
It is below the intake on the block. See picture.
As Mr Yaofeng said, it's in the middle of the block on the back side below the intake manifold. (sensor with the blue wire) My car developed an intermittent oil pressure light that turned out to be the wire had come loose and was grounding against the block and the vibration of the engine would cause a very rapid flickering.
yeah my ford bronco II dose that same flicker thing ever since i replaced the sender with a real oil pressure guage which i will most likley do with the saab...
that sensor dose not look like it esay to get too at all though but now i atleast know where it is and can test the switch now
