So I just replaced the whole exhaust on my convertible so I'm very determined now to find out where the internal oil leak is coming from. I get a small/decent amount at startup and a little bit at idle (AFTER driving, and it doesn't last)
First, I removed the downpipe to get in the turbo. Here is the video:
https://imgur.com/a/u14eZ3P
The first part of the video is me moving something that I'm not sure if it's supposed to move, but I assume it is supposed to (think it's the wastegate? Idk)
Then, going in to the turbo, that thing right in your face that's blurry, that moves a decent amount. I don't know what it is. It spins loosely if I twirl it with my finger
Then, you can see the blades clearly. There is 0 play in them, it is rigid as a brick. However, as you can see, there is obviously oil present. I don't know how normal this is
Then, I unclamped the intercooler hose and looked for oil. Nothing. Maybe a tiny bit. However, while down there, I did see that my lines are pretty damn ugly. Here are pics:
https://imgur.com/a/KLmkp1b
The first picture is the lines. Some old caked oil in various locations. Sorry for the closeup
The second picture is me on the ground, looking up at the oil pan, towards where the belts/pulleys are. The third picture is from the top. Oil is present obviously. Seems I have an external leak as well, but I'm not sure where it could be coming from in this area
If anyone can offer advice at this point, it is much appreciated as always! I was expecting the turbo to have shaft play and for me to be able to conclude the seals are bad
Thanks in advance!!
Thanks in advance!!
