1 - 8 of 8 Posts
Hey Everyone,
Took my '09 93 for an oil change yesterday at 7%. Today the oil life indicater is reading 78%. Is that normal? Dealer is saying it calculated based on my driving habits and adjusted itself, but is has never done this before. It always goes back to 100% after an oil change.
Thanks!
My 2008 does this, too. I'm guessing only Harry Potter understands the flipping algorithm because it's based on magic. I've learned to interpret the SID reading as a % of 10,000 miles, the nominal service interval. It drops faster than 1:1, but it's a reasonable predictor of when you'll need service. Typically, I get about 7,000 miles in mixed driving.
The algorithm takes into consideration engine starts, operating temperature, RPM's and other factors. it's a good indicator but not the Grail. Mine (03) always resets to 100%, but it's calibrated to 15K as 03-05's are, I don't even use it. I just change every 7.5K.
The '06 n up algorithm is primarily based on miles and is pretty screwy. I just had mine changed a few weeks ago and it only went back to 46%. The countdown is just slower but does same 9500 miles.
The '03-05 algorithm was much more accurate and did base things correctly.
Never knew about the change....
1 - 8 of 8 Posts
