I was swapping out a DI case in my car and noticed some oil that was seeping through the casing into the area where the spark plugs are. Any ideas on how this is happening, or if I should be concerned? Thanks. See picture..
Check the bolts that hold the rocker cover in place.
Sometimes you can get away with tightening them, but if it still leaks you will need to do as **** suggested.
:lol:also depends how ols your gasket is... if its been on a while they get hard and crack then start to leak so when you tighten the bolts they leak even more but worth a try.. luckily enough they are not too expensive.
