Ok the crankcase breather pipe NRV broke and threw a P1181 code. I have made a temporary patch repair while I wait for a new part. I will use the old one to effect a repair using a replacement NRV with patch tubing as per Doug's suggestions ready for the next time it breaks.
But I have noticed the car was throwing more oil and as I have effected all normal leaks (Oil pressure sensor, oil tensioner washer and O ring, and Oil pump larger O ring and crankshaft oil seal) I am still seeing oil coming from under/around the timing chain tensioner. The saab specialist say it is a notorious fault, at the point where the head gasket seals the open space where the timing chain runs at the rear of the engine directly under the timing chain tensioner. He says it requires a new head gasket.
But I am doubting that and would like advice from you guys.
1) As the timing chain cover needs to mate/make that seal maybe it is easier and less risky to remove and re-seal that area, by way of the timing chain cover. Leaving the head alone.
My only worry is that the oil could be leaking from the upper seal and head not the lower seal where the timing chain cover mates.
2) also it has been suggested that all you need to do is (A) re-tighten the timing cover bolts both those that pull the cover to the block and the 2 that pull the cover to the head and (B) re-tighten the head bolt making sure that that end is at full torque. Not sure why this would make much difference to the joint between head/head-gasket and timing chain cover.
Any suggestions or advice??
