As the title states I have an oil leak collecting on top of the cylinder head and up against what appears to be a thin metal heat shield behind the valve cover. This leak is dripping down between this thin heat shield and the head on to the exhaust manifold and making quite the smoke show when a drop hits the hot manifold and immediately vaporizes.. Already did valve cover gasket job and as you can see in the pics is bone dry, turbo and its oil lines are bone dry as is the underside of the turbo heat shield. Did vacuum pump to head seal as well and all of that cleared up a lot but still this oil collecting still persists but have no clue where it could even possibly be from. I have thoroughly degresed the engine several times and its all very clean up top but even after being cleaned within 100 miles this oil is back and only in that spot everyrhing else is dry. Ran UV dye and the oil collecting on the head had some illumination, we also noticed illumination running down the back of the block on the passenger side and on to the passenger side sub frame amd control arm. Hard to tell exactly where as axle shaft is slinging it everywhere. Thanks for any help or suggestions.
