So I've been having a rough idle issue on a new-to-me '99 9-3 convertible. There's also a bit of blue smoke coming out of the exhaust. I would also like to mention the previous owner went 10k miles without an oil change
Turning on the A/C would nearly cause it to stall, coming to a stop it would idle rough for a second and nearly stall and then normalize
I started by replacing the plugs, DIC, vacuum hoses, air filter, new belt, currently running chevron techron and gonna change the oil (again) after the current tank. I also didn't change the oil filter the first time I changed the oil filter so the current filter is 10k+ miles without a change :yikes:
Didn't fix it so I opened up the throttle body and cleaned it out with CRC. It looks like there might be oil in there? Here are pictures
https://imgur.com/a/mu6tfRA
I then took out the IAC and threw a ton of WD40 and CRC in there too
Took it for a drive and no luck. 10 minutes later, the problem went away. Running smooth now
My concern now is where is the oil coming from, and it's probably going to continue and clog up the IAC again. I think the only place the oil could come from is the turbo, correct?
The turbo looks to be in bad shape - the lines underneath are pretty rusty (but I can't see any leaks), I can't get up to full boost (no CEL's), but it doesn't seem that the smoke from the tailpipe is proportional to the boost I get. It usually just comes out randomly
My car is not an SE so it has the LPT turbo I think
So what does this mean? Is the turbo leaking internally? I'm thinking the lack of full boost may be unrelated to the smoke
Also, where is the BPC valve on these T5's? I didn't see it at first glance
Thanks a bunch in advance!
