Found the small oil leak and its coming for either the inlet/outlet hose going into the oil filter. Does anyone know where I can get that part or if its a universal fitting?
Thanks
To the best of my knowledge, this "hose" does not normally exist..
Modifications ?
Possibily the crank pulley seal, a fairly easy task.
Thanks
Those are likely just the oil cooler line o-rings. 11mm ID X 3mm cross section, high temp o-rings should not be difficult to find.
A single nut between the two lines will free the clamp that retains the lines to the engine. Pretty darn easy to replace.
Ok its been a while and the problem has came back after changing the o rings...just this time its just the hose itself...Ive looked around for these everywhere with complete failure. Everywhere is back ordered or doesnt stock them anymore. I need your guys' help if you know of anywhere to get these. They are the threaded style.
