I've been getting oil from the dipstick tube, judging by the oil spot that is always there on the plastic cover around the dipstick tube. I assumed that I had a problem with either the PCV update or I had severe blow-by under high boost.
I had someone driving behind me tell me that the car stinks like burning oil and spits out a bit of blue smoke when accelerating.
I checked the direction of the big blue check valve (torwards the dipstick tube) and little white check valve (torwards the throttle body tap).
Compression testing tonight revealed that I have between 212 and 225 psi on all cylinders. Last time I checked compression was around 20k ago, came out to between 190 and 200 on all four. I don't think that the compression would be that high if I was getting massive amounts of blow-by. Running engine with dipstick removed reveals a small amount of blow-by, which I believe to be normal.
Checked the delivery tube, then the tap where the PCV tube meets the intake (pre-turbo) and there are small amounts of sooty oil in both places.
I'm running out of things that I can think of to check.. Anybody have any ideas? Seems like the blue check valve should run away from the dipstick but all the pictures I see show it going this way....
