okay so im trying to fix the oil cooler lines for a 2000 9-3 i got how they attach to the engine by the oil filter but the ends that attach to the oil cooler dont have the same mounting plates:confused: i dont see how they are secured to the oil cooler other than just sticking them in which cant be right. is there some missing piece that i need ???
any help greatly apprecated cause this car aint moving till i figure this out
thanks
There is a stud threaded into the oil cooler. The lines will fit in with their o-rings and a single small nyloc nut retains the 2 lines. If this did not seem obvious you may be missing the stud if it was already apart.
okay so there was no stud and after much google image searching i cound that there was a steel plate with a screw that held the lines on. and out of drilling and grinding a viola a ZERO dollar fix.
