Replaced rotors and pads on the 08. One side had a rounded out hex and while the 5mm socket went in snug, the screw wasn’t budging. I heated it up and tapped it w/a punch just to free up any rust, over tightening. Still not budging.
So I went to a T40 torx socket and sledge tapped that in till it was set without holding. Put the ratchet on it and it turned. I was afraid I’d have to drill it out or create a new hex opening, which doesn’t work as easy as it looks on YouTube with punches.
Probably not a new trick, but being the torx has more bite than a hex and slightly larger ID, it’s worth a try.
