Car runs fine but is throwing P0100 open MAF circuit. Tech2 shows zero gps reported by MAF. I have 5 volts at pin 1, pin 2 is grounded and no volts or short to ground in pin 3 (red/green) wire. Working backwards, I do not appear to have power at pin2 of connector H33-5 behind the glovebox. Earlier I checked fuse 16b and there was power to the top fuse leg and the fuse was good. Checked now and no power. Swapped relay 22ish in the under dash relay box. The relay seems to ahve power on pin 30 (big orange wire) and the right hand pin of the relay but not the red/green wire going to the fuse panel.
I have two questions. First - it seems that the red/green wire that goes from connector H33-5 behind glovebox to engine bay is split in the bay and connects to injectors, maf, and other sensors. If that really has no power - would the card still run?
SEcond question - How does power get to connector H33-5 from the engine bay realy/fusebox? Does it go engine fusebox to fuse panel 16b to relay under dash to H33-5 to MAF? Or does it go engine fuesbox to relay under dash to fuse panel 16b to H33-5 to MAF?
I did do a lot of dash work, radio wiring etc so I suppose I could have knicked something in the dash or in the engine bay. I have not seen any obvious nicks to wires or harnesses yet though. And I am puzzled by the fact the engine runs smooth - that makes me think it has to be a break from MAF to whereever the wires are crimped and routed to injectors, maf etc...
