Hi,
I'm working on getting the engine out of my car and I've just a few more things to disconnect. My plan is to put the engine with transmission and perhaps also the subframe onto a rolling board and then lift up the car leaving the engine on the ground.
According to all the instructions I've been looking at (Haynes, forums) I should be able to loosen the AC-compressor from the engine and just put it to the side. However, I can't see how I will be able to lower the engine with the water pump still attached without crashing into the AC-compressor. (See image, AC-compressor in red, water pump in blue.)
Anyone who knows this process and can tell me if I must remove the water pump or if I somehow can accomplish this anyway and if so - how?
Thanks, Magnus
Thanks, Magnus
