The inside of my car was smelling damp so i decided to lift the carpets and found some water. Then i pulled the foam insulation from under the carpets, and there were literally puddles of water, half of gallon and still wooshing out if if squish the insulation.
Where can this be from? AC or Sunroof?
I know where the sunroof drain holes are (front corners of the sunroof) will clean them out. I have already cleaned the sunroof tubes that drain in the trunk (outside the trunk actually, but they used to drain inside the trunk when it was clogged).
I don't know where the AC drain hose is... one end should be under the car somewhere?
