So i'm trying to diagnose some boost issues and i'm having some problems. Bought the car in winter, changed BPC valve, cleaned MAF, got new spark plugs and DIC and the car was boosting fine. Hot weather came and i started having boost issues. Sometimes it would boost, sometimes it would not (most of the cases). I only got something around base boost when it was really hot outside - actually something a bit better than base boost, around 0.5 - 0.6 bar (sometimes 0.7).
I have opensid, no errors, running 99 octane fuel. Temperature gauge is stable (pointing all the time at 9 oclock, even when it's really hot outside - so fans / engine cooling works fine).
Cooler weather is here (especially in the evenings) and the car boost great, i'm able to reach 1000+ mair (could not reach more then 700-800 before).
It's clearly a temperature issue, but i was under the impression that the car should be able to do a a few good pulls even when it's hot outside (i can't do a single full boost pull when it's hot).
Any causes for this or things i should look for?
